Quadlock plug
Does anyone know where I can get hold of a blue 12 pin male quadlock plug on it's own. It's the type used for the CD autochanger.
TIA :)
PM me your address and i'll send you one next week if you like.
Fantastic!
Thank you very much :thumbup:
Once again Briskoda (and Lummox) has come to the rescue.:D
One more question:
Does the plug come with the metal pins inside?
Not normally. They sell the pins attached to yellow 'repair wires' which are sold in packs of 6 wires, two terminations per wire.
Just looked them up for you -
Plug is 3B7 035 447 A
Wires, two cable sizes -
000 979 009
000 979 133
Add an A to the end if you want gold plated.
It can do ;)
Thank you stu, I might still need some repair wires depending on pin availability and if I screw anything else up this weekend. :rolleyes:
I'm looking for the other 12pin quadlock connector (used for the phone connections) - same as the blue CD changer one but with the keyway on on the otherside...
Any help with a part number would be appreciated.
Also are the crimps available on their own (or in a pack) but not already crimped to a "repair" wire?
Can't just find the part No. for the green connector atm but the flyleads come pre-crimped. You insert then into the plug housing and slide on the restraining block supplied to stop them fly coming out.
Just found out some more info -
Blue (CD Changer) Quadlock Plug - 3B7 035 447 A @
Part number 3B7 035 447 A
Part Number 3B7 035 447 B
Part number 000 979 009 (Pack of 5 single wires each 60cm long with a crimp on each end)
Although the wires come in pack of 5 when my dealer ordered 2, two wires arrived and not two packs!
I have now found a UK supplier of the crimps - just awaiting costs etc, so watch this space for an update...
Bad news regarding quadlock crimps on their own...
Yes they are available, but only in packs of 10,000 and at a cost of just over
