Steaming up in the rain?
Ours smells damp. How do you go about fixing the problem if it does leak?
Took ours to the dealers, fixed under warrenty :thumbup:
What did they actually do though as our fabia is 2001 so is a bit past its warranty ;)
is there a DIY fix?
Mine has been steaming up terribly since i got it. as soon as i get in the car it's steamed up bad.
I usually try and stick the re-circulation button on for a while and wait 2-3mins before setting off. air-con can help sometimes... but i generally find on a morning that hot air clears it better.
my passenger side seems to clear very quickly compared to the drivers side, so its booked in for dealers to have a gander on tuesday (as well as my rattling gear box)
Had my vRS from new on a 52 plate and its always steamed up really quickly when its raining but flick the air con on and it goes just as quick. I thought this was normal and have never really had any reason to think otherwise......till now....... Hmmm?
Hmm, funnily enough my dad's (1997) Toyota Avensis is exactly the same- need AC to clear the screen.
it really annoys me as all 4 other cars in the family have no AC and can clear their windows no bother. I find it a bit wasteful having the AC on all the time with regards to fuel consumption (apart from a weekly blast for 1/2 an hr to keep the seals wet...)
Me too, smells like dampness, and the windows are always wet on the inside of mine.
Mine has always done this , as stated AC on for a few mins is the only way to get rid of it , my car isnt damp smelling and has no leaks.
Mine only started to do it after I had a front footwell leak, which was sorted. But the fogging remained.
I presumed that it would be some moisture still in the car but this was over a month ago and it still does it! Its not a problem as A/C sorts it and there are no visible leaks but I need to really give it a good checking.
I also noticed that if Im washing the car, as soon as water hits it, the windows mist up! Might have to have a proper inspection when I get some time.
Mike Pembo
Mine does that too , theres definately no leaks tho! Im assuming its the difference in temperature of the hot water against the slightly colder glass?:confused:
I suppose it could be, however the latest time I washed my car it was a cold ish day but with cold ish hose water so who knows!!:confused: I was going to get some Rain X Anti Fog stuff today but
