Expert advice needed please
My Octy vRS has started jerking quite badly, when I start driving from cold.
Once its warmed up a bit, its fine.
I never had this problem until I took off the recirc valve and replaced it with a baileys one.
I have since put on the standard one again, but its still doing the kangaroo impression.
I have checked the jubilee clips on the recirc valve and they are all as tight as possible.
Does any one know a possible reason its happening, or had a similar experience?
Any help/advice would be greatly appreciated.
Thanks in advance.
Damian.
Do you know if the car has had any coil pack failures/changes in the past?
Im not sure mate
I only bought the car a couple of months ago.
Do you think its the coil pack then?
I'm still fairly new to this vRS game but experienced a similar problem myself shortly after getting my Oct vRS. I was advised to clean the throttle bodies, which I did and all was well again...............took no more than 5 mins to sort.
Good luck
Lance
just dont disconnect the TB as you'll need to have someone with Vag-Com reset it.
also try cleaning the MAF sensor with some contact cleaner.
