Abs
Hi
The ABS light has come on my 2001 Fabia 1.4 16 v
I have read and cleared the codes
012d ABS return flow pump
0116 Main ABS valve
However 012d returns with the ABS and traction control light
Can anybody help
Ta Chris
there might be an air-lock in the abs hydraulic unit.... they are notoriously difficult to bleed. have you changed the brake fluid recently or had any work done on the brakes/clutch in your car??
Check the fuses on the top of the battery (long silver ones) I would expect one is blown.
:)Thanks for advice ,looked at fuses and they seemed to be ok so had to take to Skoda Dealer and paid
Thanks for Advice but no work done on brakes recently,turned out to be fuse located above battery .
Thanks for your time
Ta Danyboy
Thanks For Advice but brakes are good and have not been worked on recently,turned out to be fuse above battery.
Danyboy
