Some Fabia rear axle measures
Can you guys tell me what are the radius R1 and R2 from my picture. I need to manufacture this myself, because I can't find any broken fabia rear axle.
I need this because I want to put rear Fabia RS brakes on my Golf MK2. I need rear brakes because I can't manage my speedo to work. So I need rear brakes to connect rear ABS sensors for my speedo to work.
So if anybody have rear axle beam lying around, can you meause it for me???
do you mean the front brakes from a fabia on the back of a mk2 golf???? there will be no handbrake mechanism if you do that...
mk4 golf rear brakes will fit a mk2 golf....... and they have abs sensors
I mean rear Fabia brakes on rear MK2 golf. Why wouldn't I have handbrake mechanism?
Are the MK4 golf sensors the same as the Fabia? Because on Fabia wheel hub there is magnetic ring. Is it the same at MK4 golf?
from the original post i thought you were talking about the front brakes of a fabia being put on the back of a golf......... but if you are using the rear ones then that is ok...
why do you need to do this??? isn't it easier just to fix the speedo??
How? I have swapped Fabia RS in my Golf MK2. So my speedo doesn't work beacuse it reads speed from ABS so I need to put Fabia brakes. So now I hope thet this will work. I can't put front Fabia wheel hub in place of my golf wheel hub, but I can put rear brakes.
Edit:
use the mk4 golf ones. they are a direct fit
No it's not direct fit. Golf MK2 stub axle has carier for brake caliper and MK4 golf like Fabia doesn't.
Maybe is MK4 brake caliper direct fit. And also MK4 Golf doesn't have magnetic rotor for ABS.
MK2.....................MK4.....................Fabia
R1 - dunno but the PCD for the wheels is 5 x 100 on the fabia - you work it out ;)
As for r2, dunno
As for r2, dunno
R1 is not 5x100. 5x100 is on the wheel hub (No. 10 on the picture).
are you using the fabia clocks/speedo or are you using the original mk2 golf one??
Everything is from fabia. Complete dash with clima.
