How to change the interior lights??? HELP ASAP PLS!!
Hello all.
2 days ago, I was trying to take off the plastic that covers the welcome and map lights with no success.:thumbdwn: :thumbdwn:
As so, I need urgent help on how to remove it and put it back on, this because I pressed it a little and puxed it forwards and the plastic moved about 3mm, now I cant put it back on the way it was:( .
Can anyone help me?:confused:
Thank you all!!!:):thumbup:
It just prises out.
dont wanna be pain in the ***, but, any site or anyone with pic explaining? thanks.
anyone? pls :)
Just pull it down from the edge nearest the windscreen. It tells you this in the manual! ;) :P
small flat bladed screw driver, loosen both sides and i believe it clips off on the side facing the rear of the car, then u slide it towards you.. and hey presto..
although i just got screwdriver behind a side and it flew off at speed towards the floor!
Just pull it down from the front edge with you fingers. Thats what it says in the manual!
thank you all....gonna try that as I go out tonight..tell you later how it went.
I thought there were two phillips screws that secure the light fitting in, behind the clear lens at the front.
Yup there are, i know... i've list mine and the light rattles!!
There probably but he only wants to remove the lens to change the bulbs...
well, I have to say that I feel a little stupid right now, that because I came here to ask because I was afraid to break the lens.
After all, it just popped off.
Its all good now.
Thank you all!!
