SDI Service inspection
Hi guys
What should I replace at 65-70k? I have recently changed the oil and filter when the "oil service" instruction came up.
I'm thinking: Replace glow plugs, Air filter... but not what else? :confused:
Obviously I'll inspect brake fluid level, pad depth, coolant levels etc.
I know they say its filled for life but changing the gearbox oil makes a tremendous difference to shift quality. Not a difficult job but extra expense outside the "normal" routine servicing.
What is your pollen filter like?
Thought about upgrading your headlight bulbs?
  • 4 weeks later...
How do guys. Thanks for the replies. Only just remembered about this.
The cam belt has been changed so that has been covered. Where is the pollen filter?
  • 4 weeks later...
Pollen filter is under the dash on the passenger's side of the heater. Definately worth replacing. I buy mine from German Swedish and French.
Have you had the brake fluid changed? If not I would. My Fabia just needed two new wheel cylinders at 100K because no one had changed the brake fluid earlier.
I was gonna say brake fluid too
it should be done every 2 years regardless of mileage as it absorbs moisture and therefore can make your brakes spongy or pull to one side
