Nut/washer size for engine cover 'rubber'
Hi,
Gave someone a lift the other day and I got a comment regarding the taka-take (MillTM) sound being worse than usual.
Engine was cold so didn't think much of it, pretty normal :)
However a further check revealed the nut/washer holding down the rubber in which you slide the engine cover bracket is missing :rolleyes:
As I have a homebase across the road from the office, does anyone here happen to know the size of the nut I'd need to replace it?
Hopefully I will get my replacement cap for the water reservoir as well today as that went faulty a while ago (causing the lovely beep/flashing light thing on the temperature indicator).
Must be getting near the 60k mark :rofl:
Will be an M8 nut (10mm spanner size). Not sure on the pitch though.
Seems to be a 'normal' thread so kinda hoping for 'go to DIY store and buy some nuts of that size = fixed' scenario :D
Thanks for the info :thumbup:
