How do I?
Ok, I fitted a Parrot handsfree kit the other day, but -
I couldn't take the interior light out to finish running the wire for the mic, I got the lense out and the biege plastic surround (around the switches) but could not see any way of removing the unit itself, no visible screws or anything. any one know how I take it down?
Also one of my speakers has been distorting for some time now, how do I remove the speaker grilles?
Dont know about the light fittings but the speaker grilles are part of the door card and are hot melted onto the door card. So you will need to remove the door cards to get to the speakers.
I ran my mic lead up the inside of the door trim/door seal and have the mic at the top of the door trim. Easy ish to do, and easy to remove if need be.
Hardest thing was sighting the control box.
I've already run the cable up the pillar and across the roof to the centre (I want the mic in the middle of the car so passengers can use the mic too).
I just need to take down the light so I can run the cable behind it instead of the wire running where you can see it! I just cant see a way of taking the damn light down!
A word of cautionary note.....:eek: do not break the speaker grill I cracked on of mine and enquired about a replacement
Have a look here,
=== VWFANATIC ===
Hope that helps :thumbup:
Have a look here,
=== VWFANATIC ===
The clipping on the Superb interior lamp is slightly different but once you have the lens off it's pretty straight forward as you can see where the clips are and with a flat bladed screw driver you will be able to pull the lamp out easily.
