Cruise Control Light
Does the Octy II Elgance show a light on the dash like the VW's do when cruise control is turned on.
I can't get to look at a manual as it isn't my car, so figured I would just ask
Up to and including 2006 models you don't :thumbdwn: but the newer spec'd 2007 versions do :thumbup:
I dont like the light on my passat. I used to just leave cruise in the on position with the fabia but if i do that now i get an annoying green light ruining the red and blue look :(
I have to keep switching it to off. Your lucky not having a light!
Adam
Isn't mine as i said just asking for a relative.
Thanks for the replies guys :)
Adam
I don't know where the light is on the Passat. The Octy is a symbol rather than a light, like a tiny red speedo, it shows in the speedo dial when you SET the CC, goes off if UNSET either manually or when you brake.
It is not on all the time when the CC switch is ON, only if it is ACTIVE.
Ahh the touran one turns on when you flickthe top switch to on and doesn't go off if you touch the peddles etc.
