camber angle
does anyone know if this is adjustable? one of my tyres is showing uneven wear and the from pictures i've found it looks like the camber angle is out rather than the tracking.
have you had the tracking checked ?
camber angle strictly speaking is not adjustable , but the technical data somebody posted up for me a bit ago has mention of adjusting the camber by shifting the engine-gearbox assembly carrier , which i take to be the aluminium wishbone mounting assembly , its does also say that new bolts/washers must used after adjustment HTH
no i've not had it checked, i will tho just to check, but from the type of wear plus the road noise from the tyres i suspect it is down to the camber angle. i've hit a couple of big potholes and i think something has got bent.
My local dealer told me the camber is only adjustable my moving the subframe.
:iagree:
can only be done acurately by using a special jig, and by moving the whole subframe
