vRS Power Feed In Boot
Is there anywhere I can grab a power feed from in the boot of the vRS - is the wiring in for the socket used in the estate or is there somewhere else I can take a feed?
I also need to grab the speaker cables too - any easy bits to grab a feed from?
If your feeding an Amp then I would suggest you run a suitable cable from the battery
What are you feeding, as above if its a amp, only run it straight from the battery
I agree with the above...
I can help with a wiring route if needed.
Tom you have a PM.
Tom you have a PM.
You have a reply. :)
You couldn't send it to me too Tom could you? :)
