Sidelights goosed ?
Just a quick one :(
I have 52 Plate vRS, but noticed the other day the my side lights are not giving out same brightness from each headlamp. Dipped and Main ok, (different bulb).
Dealer recently replaced motor under warranty, presumably not connected to this problem.
Any thoughts, earthing strap, bulb going, loose connections ?
Intend to look at the weekend, because its dark monring an night at the moment
Cheers for help / advise when it comes !
i would try some new bulbs , they sometimes go a bit dark inside the glass of the bulb , failing that there could be a fault with the earth connection but that would probably make all the bulbs dim
1) Make sure both sidelight bulbs/connectors are on securely and sitting in the right place.
2) Take both bulbs out and compare them. Making sure you remember which one's which! Then swap 'em over and see if there's any difference.
J.
