transfer old files from laptop to new pc
Is there a easy way of doing this i have a ethernet cable, can i just plug one end into the pc and one end into the laptop? and somehow access all my laptop files on there? or do i need something else?:o thanks in advance:)
i took a mates advice on plugging the ethernet cable directly into each of the network cards.... and clciked run typed in \\"name of my pc"\c$ but nowt happend just said it could not find network or something....??
a normal network cable won't work as its meant for a normal network. to connect them directly you would need a cross over cable and make sure they are both on the same network settings other than the ip adress, make the last number 1 digit different :)
or use a hub, might be able to do it with a USB cale but it would probably be slow.
As above, then run the windows network setup.
ahh ok thanks bengie! ill go shopping tomorow for one :) does this transfer all installed programs too?
nope
it just provides a link between the computers.
