Abs
Hi... im a newbie on here.. does anyone know if i can reduce the sensivity of my abs as if i hit a leaf the abs kicks in and its taking me forever to stop if im hard braking..
My GF has a mini and the brakes are AMAZING!! looks like VAG are skrimping on costs
Oh i have a sat ibiza not a Skoda :-p
if you really don't want ABS just snip one of the ABS sensor wires. By the way - please don't! ;) It means no ABS and no ASR
There must be a reason for the ABS to kick in, no? Either the wheels are about to lock up (which means brakes are fine ;)) I can stop plenty fast without the ABS kicking in so maybe it's poor tyres?
Pretty sure the ABS settings cannot be tweaked with vagcom
my friend has a vrs with eagle f1's on it and he gets the same problem probably yorkshire roads!!!!!!
thanks for your help :-)
It depends. Some systems do have the option to code them for "bad roads". However, I'm not really sure what this does, nor can we advise whether the module in question supports this without complete details from the module.
-Uwe-
ill have to get my friend over later with vag com as my lap top is down at the moment and ill post the data later if that would help...
Full scan of my car a few fault codes too.... he was using 3.1 vag-com i think
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 036 906 034 DG
Component: MARELLI 4MV 4593
Coding: 00071
Shop #: WSC 06403
VSSZZZ6LZ3R074883 SEZ7Z0A1479040
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00124
Shop #: WSC 06405
1 Fault Found:
65535 - Internal Control Module Memory Error
35-00 - -
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16524
Shop #: WSC 06405
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 920 H
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00445
Shop #: WSC 60089
1 Fault Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 62 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06405
1 Fault Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00121
Shop #: WSC 06405
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 37 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06405
End -------------------------------------------------------
These two aren't very good, in relation to the issues you're having. :eek:
Coding: 00124
Shop #: WSC 06405
1 Fault Found:
35-00 - -
Coding: 16524
Shop #: WSC 06405
1 Fault Found:
what causes it you any idea??
do you know wher th ABS control modual is located on a 6L Chasis.
in addition to this i had the catalyst bank 1 below efficiency code up earlier!! not very happy about it all had loads of problems with the car...think it needs to be going!!
I would think the ABS control unit is the thing attached to the bulkhead - kind of below and behind the airbox. Looks a bit like a square ECU, but is obvious when you see the solid brake pipes going into and out of it. :)
ahhh i know where that is lol gonna go have a look and clean the connections
too dark now!! i've read this can sometimes solve the problem
