electronic window fault????
I have a fabia yr 2000 w plate 1.4i the electric window on the front passnger side does not close after i open it using the controls on the driver side. I have a lad with a vag-copm in reading who wants to help me but does anyone know is this as simple as resetting a certian code? help thick novice who will pass the knowledge onto a lad with a Vag-Com:confused:
Does it work from the controls on the passenger side? Sounds like a duff switch to me.
yes it works on the passenger side used to work on the drivers but you have to pull the button 10 - 15 times before it works
