06 Fabia TDI - Bulb warning light
My bulb warning light keeps coming on when i go over a bump, i have checked my bulbs and the offside fog light bulb does not work, i have swapped the bulb a few times and still the same, so no bulb issue. It could be the whole light cluster with a loose wire etc..... any other users had this problem ???
I've been suffering from exactly the same problem for the last 2 months. Every time I touch the brake pedal I get a buzzer and a warning light on the dash.
None of my bulbs are out, and when my car was serviced last week the dealers checked my rear light clusters and couldn't find anything obviously wrong. The cheeky sods even replaced a perfectly good bulb and charged me for it!
They're having my car back in next week for a day so they can check the wiring to the rear lights and possibly to take the dash out (and therefore to insert a new annoying rattle when they replace the dash!!). New door seal is being fitted at the same time too.
I've been suffering with the bulb warning whenever I hit the brakes for the last few months. Whenever I've checked the bulbs they've been working perfectly - finally got so irritated by the incessant beeping that I booked it in. Lo and behold it's the high level brake light. It's been three weeks and the parts are still on order, spose I should chase them up.
Rear Fog light - there's only one bulb that works IIRC. It's an EU thing to use only the bulb on the drivers side to prevent them being confused for brake lights. They are making the irrational assumption that people only use them when it's foggy ;) . I've had a few VW group cars and they've all had only one working rear fog light.
Mine is booked in on Monday, i suspect it is a dodgy connection or short somewhere near the offside rear light cluster, at least i do have a target for the warning ''beep'', if all the bulbs were working i would be a bit confused.
Dealer does not have a clue..... i thought the car had two fog lights but as you said it has only got one !!!!!!! It is booked in for the whole day next week, does anybody know if this fault is common throughout the fabia range ??
It does it on my fabia Vrs and is driving me bloody mad, pinging on and off. Its done it before and the dealer just reset the registered code but didnt really know what it was.
Mine's fixed now. New high level unit fitted his afternoon - and the lovely red glow on the parcel shelf tells me it's working. I'm off for a drive in blissful peace...
