Fuel filter change - Fabia vRS
I'm about to change the fuel filter on my Sept. 2003 Fabia vRS. Will I need to bleed the fuel system of air following the change. The job looks pretty straight-forward but is there anything I should look-out for. Thanks.
No you wont, fire it up and away you go. If it cuts out just turn it over, wont take long to go due to the high pressure fuel system.
Make sure you change the seals on the return valve.
