selecter lever lock for auto gear box...What is it?
can anyone tell me why i have a fuse in slot 43, it says its for
( CENTRAL CONTROL UNIT , SELECTER LEVER LOCK FOR AUTOMATIC GEARBOX )
where is this unit, mine is a manual or is it just part of the wiring circuit for the car.
can anyone point me as to what else uses fuse 43 that they know of...
thanks all
spevie
Central control unit/onboard supply control unit.
The main central electrics ECU that controls lighting etc.
You dont have the selector lock.
hey lummox, i fixed a couple of more wires under bonnet, i now have the battery light flashing along with the others......hahaha.
just wondering now if the ECU has a problem, just romoved the door panels and metal skin to check the wires for the interior light, was a bit damp so cleaned and refitted, still same.
i can only put it down to either the POD or the ECU playing up. as i said if i remove fuse 43 then all flashing stops but stops the indicators and stuff and checked all wires...
Might bite the bullett and see what stealers make of it, why do i feel like i have to leave n arm n leg as down payment ????:(
spevie
