Fabia 1.9tdi lfront lights problem
Hi,
My nearside side and low beam lights are gone. I swapped the side light left to right and the bulb is fine , checked and swapped fuses and still no luck. It looks as thogh there is either no power or no earth. Only just happened - has anyone had a similar problem ? The main beam is fine
Check the wires on the back of the light switch.
Had similar on an octy and this was the cause.
Check wires when I sapped over the bulbs ! iIt is obviously something to do with the wiring. I wanted someone who had a smilar problem that wasn't just the connector falling offf !
Do you have power at the back of the light?
