Mark II 05 L&K to Mark II 07 VRs differences
Had a Mark II L&K and now have an 07 VRs. Three initial difference I cant explain and because its a company car I don
1) On L&K when I switched on ignition there was an annoying beep until I put on my seat belt, in the VRs no noise!!
It's there, just not switched on.
2) On L&K when I used the cruise control there was no indication light on the dash, in the VRs I get a yellow speedo light thing!!
2007 MY Revision
3) On L&K when I locked using the key fob just got flashing indicators, on VRs I get a beep as well!!
Again it's there just wasn't switched on in the L&K when you had it.
Thanks VRStu
I thought the seat belt beeps where part of the safty legal requirement!! What about side lights , only get main light on indication can this be switched on?
Smilo
You will get seat belt bleeps when you go above 20mph in your VRS. My MK1 L&K used to beep on ignition - v. annoying. My VRS is much more easy on the ears...
So is mine - I turned it off!!! :rofl:
How do I get the beep on lock without MaxiDot or Vag-Com?
Possible or not?
Thanks in Advance.
Possible or not?
Entirely - visit your dealer
