Drivers door handle
Hi guys,
I've been trying to get of the door handle on my fabia (driver side). Because the cable between the outside door handle and the door lock has been pulled out and I can't get it back in without removing the handle. I think I need to slide it to the lockside and pull it off but it doesn't come off and I'm afraid to break it.
Anyone had experience with this?
Meanwhile I'll be searching the forum.
Grtz
This one is solved thanks
Any chance you could share your pearls of wisdom with the rest of us? :P
Off course,
I didn't take it off:) My problem was the little cable so using a torx key (I believe T15) I unmounted my keylock and then it was a piece of cake putting it back but my guess is once you take the barrel out you can just slide the handle to the side and take it out.
Hope this helps for you.
Grtz
