Calling anybody with an Octavia II Estate
Could someone possibly do me a favour and measure thier back side boot windows for me, just the see trough bit not the whole glass. Need to order some window stickers for my business but have not got the car yet!!
Many thanks in advance.:thumbup:
Ianwilly, the problem is giving the dimensions for an irregular shape. You could do with a picture of the windows handy.
For the offside window, looking at it from the outside:
The base is about 68 cm. The right side which is nearly vertical but sloping to the right is about 36 cm. The top is a curve going down from the right to the left. For about 37 cm it slopes down at a small gradient (going downwards by about 5 cm), then for about another 47 cm slopes down at a greater gradient. The last few cm are nearly vertical. If you could supply a picture with dimensions you need like x, y, z I could measure them.
Another method would be to take a few pics of the window whilst holding a tape measure across it vertically, horizontally and diagonally etc.
I've not got an estate so can't do it for you sorry
Thanks for the fast response.... the dimensions i need to fit are 38cm wide by 26cm high. Cheers!!:thumbup: :thumbup: :thumbup:
When the height's dropped to 26 cm, the width you've got is about 43cm, so it seems OK.
I will remaeaure as there is a tinted bit to allow for now I've read your original question
Thanks Prasg, much appreciated. :thumbup::)
Sorry I misled you. Unfortunately, the clear part for a height of 26 cm only gives a width of 34 or 35 cm
No Worries.......Should still see the letters, i will just not have them borderd.
Is there a border around the sticker that doesn't matter if it is obscured? Or can you cut a bit off?
I can have it borderless if i want so it chouldnt be a problem.
