K line voltage test
Hi,
I have a skoda fellicia 97
A serial cable from Andy (ECUFix.com)
VAG-COM 409
the test is ok but each module gives "no response from controller"
The voltage over pin 7 (k line) to pin 4 (vehicle ground) is 10.4V
And to pin 5 (signal ground) is 0v
I guess it should both be around 2v
any idea where to search
thanks
Open-circuit voltage is not very meaningful. Take a 1 K-ohm resistor and see if you can "swing" the K-line to ground and to +12 through the resistor.
Pin 5 is irrelevant -- VW cars often don't have it connected to anything.
-Uwe-
Thanks.
I tried that, K line drops to 1V with 1K-ohm resistor to pin 4
and goes up to 12V with the resistor to pin 16
I also hear clicks from the panel when it goes down to 1V
it looks OK than, what else can I check
Which controller are you trying to reach? Which engine is installed?
The engine is VW 1600 AEE
I am trying to reach the Airbag controller
But there is no response from all controllers
Using Ross-Tech's HEX+CAN-USB interface, I can scan addresses 01 - Engine, 15 - Airbags and 25 - Immobiliser on my Felicia 1.6.
