CD problem
Hi, i recently bought an 05 2.0FSI elegance Octavia and i am having a problem with the in dash cd player. The player happily accepts discs but when i eject them a cd error message shows and i have try several times before it finally gives back the disc. Anyone else had this problem and how did you solve it? I have also noticed a rattle when i rev the engine and release the clutch to pull away, i think it is the exhaust rattling but cannot be sure. I hope it is nothing more serious, as anyone had this noise? Thanks.
Welcome to Briskoda!!
I have an 04 Fabia vRS and occasionally i suffer a similar problem; i have found that after pressing eject, and my cd not being ejected from the stereo, if i allow the cd to be reloaded and skip through a few tracks, and then press eject once more, the cd is ejected as normally...
It is a common fault with many slot-loading mechanisms; unfortunately the only cure is a non-oem stereo (as they seem to have more reliable ejection mechanisms)
As i say this only happens occasionally to me, and if this is a continuous fault then i might suggest you get your dealer to replace the unit for you...
on the subject of the rattle; it sounds like a loose clutch cable; probably just rattling against something... i wouldn't think it was too serious and is relatively easy to fix (depending on how technically minded you are) if not, pop it into your dealers....
Hi Bomski, thanks for your reply i will get the cable looked at and have a play around with the cd player. :thumbup:
