How do I find out when the next service is?
Someone posted on here a bit back saying there was a way of doing this through the maxi dot. I can't find the thread however.
if you shut all the doors, hold down the mileage reset kn0b (which will reset the counter) whilst holding it turn on the ignition.
So you tried it then :P .
No need to hold the kn0b whilst turning ignition on, turn on ignition and hold the kn0b in.
Yeah and min now say's SERVICE NOW !
Opps :P
Hi
Mine also says Service Now! - after checking using the above method (less than 10K miles on clock!)
How do you actually check the milage to service and how can it be reset if an error has been made?
Help!
Steve
