Wheels Tires Problem
HELLO FRIENDS, I HAVE OCTAVIA RS WITH WHEELS 17 x 7,5 35 OFFSET 5-100 AND TIRES 225/45/17,IS THIS THE RIGHT SIZE?? THE PROBLEM IS MY BACK TIRES IF THE CAR GO THEY FIND IN THE FEATHER.WHY?????????
SORRY FOR MY ENGLISH!!!!!!!!!!!!!!!!!!!!!
The wheel and tyre size sound ok to me, so what would be causing the tyres to feather I dont know.
Have you struck any objects or pot holes recently.
Sorry I Forget Tell I Have And Eibach-bilstein 2 Points Lower From <> Height
I thought Eibach didnt make springs for the RS?
Did you have the suspension alignment checked and adjusted when you had the car lowered? My son had a similar problem with his BMW which was due to excessive rear wheel toe-in following work on the rear suspension. I suggest you get a 4 wheel alignment check for your car if this is possible where you live.
eibach dont recommend there springs for the vRS
