Extra gauges.....
Well pleased with this....not much fu*king around to get it sorted either!!
To be honest the pics don't do the gauges justice.....still who cares:D
Really nice!
Looking good! I just fitted mine a couple of weeks back. I went for the same combination but positioned them differently.
Please excuse my complete inability to use a camera.
those are nice......what gauges are you using Phil?
They're Megan racing gauges from America, unfortunately that means that the sender thread was imperial and the oil temp reads in Fahrenheit but it's not a major problem.
they look great!
Very nice gauges VRSPhil!:thumbup:
I opted for the standardish look.....I really wanted my gauges to have matching red needles, but couldn't find anything like that for all the tea in China..... Mine are green back lit so they match the other dials just nice.
You should have gone for the VDO ones then Steve, as i wanted the same standardish look and found these to be the closest
How much, and how hard is it to get these in and running? Look good, but not sure if have the money or the patience.
The actual gauges are ease enough to fit as all you have to do is tap the dimmer switch from the headunit and wire a switched 12V supply from under the drivers peddles.
Its what the gauges are attached to what causes probelms
I fancied VDO gauges too but the ones I could find seemed odd (3 bar on the boos gauge for example).
Mine went in without much problem, It took about 2 hours from the gauges arriving to being fully installed, would probably be a bit quicker second time around.
mine was a little longer as i was a wuss with the scuttle panel and couldnt get the original oil pressure switch unclipped and ended up mullering it and having to repair it.
Very similar to my autogauge ones:
they look well them.
Ic3man, where did you get your pod from? or was it a universal one trimmed to fit?
Trimmed to fit - RGM.
Same as mine then. lol :thumbup:
