2.0 petrol - cambelt change
Hi all,
I'm having the cambelt changed by a freind of mine. I've looked in the haynes manual and you basically just need to renew the cambelt. I'm going to change the auxilary belt at the same time. Is there amything else I should/need to change? Is changing the water pump tricky?
Thanks.
it's definately worth changing the water pump at the same time whilst you've got in all apart.
also change the timing belt tensioner as well
