A couple of niggles......
Apart from the glow plug relay, I
and sounds like a tractor.
TDi you say...
I would say 1 isn't normal it should be a fairly consistent idle speed. Certainly the PD170 cars i have driven have never done what you describe.
With regards to 2 not a clue mate, but it might be in the manual.
Either the system thinks a door/window is still open/failed to lock, or a system fault it says.
Mine idles at around 750rpm except on a cold start where it sits a bit higher for a short period of time.
I've not noticed how the LED behaves.
Steve
Mine's never done 1 and I've not noticed 2 but I'll have a look later
Thanks for the feedback, even the facetious one. I think I
i've only had this happen once when it idled @ 1000rpm but it didn't sound like a tractor, as to the LED staying on not happen as yet.
I prefer "smart as$" to facetious...:rolleyes:
Just a little light hearted banter.
I was taken as it was meant :thumbup:
