Unusual error codes - Octavia RS Mk1
VAG-COM Version: Release 311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT G 0002
Coding: 11500
Shop #: WSC 31480
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
Address 08 -------------------------------------------------------
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U0 920 911 C
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 19412
Shop #: WSC 31480
TMBER41UX48752123 SKZ7Z0D2474266
1 Fault Found:
00462 - Control Module for Seat Memory: Rear (J522)
49-00 - No Communications
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 46 Komfortger
If your car does not have seat memory, do the following...
VAG-COM > Select > 19 - CAN-Gateway > Coding - 07
Now code the module with exactly the same value as it has right now, which would be 00006. This will initiate an update of the gateway installation list and after that the control modules should know that there is no seat memory in your car and they should ignore it then.
Please report back if this solved your problem.
Additionally...
00932 - Ross-Tech Wiki
01274 - Ross-Tech Wiki
Thanks Sebastian... Exactly the kind of advice I was looking for :)
