Clutch Bite
Im not sure im being paranoid but im sure my clutch bite is biting further at the bottom with a very slight judder when coming off clutch, but that may be me. I have no clutch slip whatsoever. Ive been advised that the clutch servo is all connected through the main brake resevoir and may help with a full oil change and bleed. The only thing that has been touched on the car is a brake upgrade from 256s to 288s then 312s at the weekend.
With your signature stating.. Too many mods, and it not being your clutch. I would ... Start looking into possibilities of a new clutch and flywheel. It mostly sounds like your Dual Mass Flywheel causing the juddering.
But clutch is defo not slipping and my mods are only like a normal vrs remapped. th ejudder may be me dragging th eclutch thinking that the car will stall because of where the bite is though
