Passenger Window
Hi,
Just would like to know, does the control on the drivers door have two settings to close the passenger window, just the same as the drivers window. One for shut, and the other one for complete open or close automatically.
Because mine has stopped working for the passenger side, it works fine with the normal close, but the auto part does not work, is this right or is there a problem?
i think it might be a case of having to reintialize both windows again for the one touch system to work
Should be able to do just the passenger side one, with the window up pull and hold the switch up with the ignition on, you should hear a click. One touch is then set.
