Diesel vRS - 1st service
Hi all,
Does anybody know what is included in the 1st service?
What is checked and what is replaced :confused:
Many thanks,
Fabby.
it's just an oil and filter change.....
my one was oil and filter and also the pollen filter was changed aswell
and a sump plug ;) ...and a lot of money. Have a check around the independents before you book it in. You will get a shock at the difference. ;)
and tell 'em to be careful with your sump plug... mine had 7 services and on the 8th the sump was due to be "re threaded" which may not work... then you're looking at a new sump :( the garage told me sometimes the threads only last one service!!! and they don't replace under warranty either :( oh , and yes, I forgot about the pollen filter... changed every service I believe.. :)
Sump plug should be replaced at the service IIRC. If you're a one service a year person, it'll also include an "inspection". If you're a two service a year person, just get them to do a "lube" service this time :D
Chris
So to keep the car in warranty you have to pay nearly
To keep the warranty in tact, it has to be serviced by a VAT-registered garage using OEM (or better) parts and to Skoda's service schedule. No need to go near a main dealer at all :D
Chris
