Standard Head Unit Size???
Will i need a facia when i replace the standard HU in my octy vrs chaps???
putting my active black sony in it's place, hope it gives the speakers a bit more growl!! although i hope it isnt too much as it is 40wx4
can you help my fellow friends!!
Hope so,
Nick
Nope, no need
Cheers Q, didn't think so but saw a pic of the fabia and that did
Indeed they do, but we have normal din sized slots.
Tip of the day:
remove the glovebox...becareful of the glovebox light connection....to give better access to rear of HU and aid relocation of cables....HU will be a tight fit.
indeed... top tip.
you'll need to get your hand in through th gaps in the cables already there.
i found it best to ease the cables upwards and towards the glove box side of the dash slightly.
there isnt much room back there at all, especially if your going to use a ISO connector block.
I had to remove glovebox to route power to battery for my amp, which came in handy for cable relocation when I got the RCA feeds plugged into the H.U. It was a tight enough fit just getting the HU to clickin because the signal amp was making it tight, but with the RCA leads too, bloody hell! :D
The top of the glovebox also comes in handy for wrapping up excess power and RCA cables. :D
Tip of the day:
This always confuses me. I bought a Blaupunkt Daytona and the wiring doofah and it slotted right in with no problems :confused:
