Brakes From vRS to TDI
Is it possible to install front brakes from vRS to 16" SIRIUS on 1.9TDI ? or I have to change Alloys for this ? Any ideas witch brakes kit can be fitted to 16" OctyII? (After chip I spoted that I need more powerfull brakes)
P.S.: And do anybody know the brake rotor diameter for vRS?
AFAIK, the 312mm brakes from the Octavia vRS will fit the 16" alloys of the Fabia vRS (just!) so you ought to be in luck unless the rims on your wheels are particularly deep...
mk2 vrs to mk1 fab ? you sure ?
Think he means:
MK I Octy VRS 312mm fit under Furby 16" wheels
so
Hopefully Octy MK II 312mm brakes from VRS should fit under the TDI's 16" wheels.
ah
