Centre Console Best Silver Match
Hi
Planning on fitting the sat nav to me car when I pick it up. Its Sport just wondered if anyone knows which silver paint matches the rest of the trim the best as Im planning on painting the centre console.
Rich
You can buy the plastic centre trim in silver as per the VRS for about
Hi
Unfortunatly I dont have the dual climatic air con contol so it isnt availabe in the silver so Ive read anyway.
Rich
Not so. The vRS is available with and without dual zone climate control, so the trim is available. :)
Umm I knew the vrs is available with both but the trim for the mfd2 is different to the standard stereo but am I right in thinking you can order a vrs with sat nav but without the dual zone dubbery? If yes and part is availabe anyone know the number?
You can order a VRS with or without the Jumbo box, IIRC both these combinations can be ordered with or without sat nav.
Octavia-vRS.com - MFD2 Install Guide
Might help failing that a good dealer should be able to help you :)
I'm not 100% sure that list of part numbers is comprehensive, but VRStu will be able to tell you.
EDIT:
Just looked at the spec book and it does say you need dual zone on the VRS to get sat nav, however it doesn't say that is the case for the rest of the model range.:confused:
