Lowering springs
How would you go about fitting lowering springs? is it a hard job?
Ta :)
Ta :)
without the right tools it will be a difficult and possibly a dangerous job , so best left to a garage unless you are a reasonably competant mechanic
Ta :)
Fabia-vrs.com - Home Page is your friend. As stated special tools required though
Theirs a guide on here somewhere.
Takes me twice as long to do than a garage :rolleyes: I think its like everything else in life. One side I may do quick but then the other side can be a complete bitch :rofl:
The tool is well worth investing if you decide to carry it out yourself.
A hub splitting tool is a must, as is a good set of spring compressors and a m14 spline drive socket. and various other spanners and sockets.
If you are in any way unsure, dont attempt it without a backup plan ie a good mechanic to rectifie your mistakes :thumbup:
yea from the sounds of things i wont be attempting it ever :P cheers for the info guys ^^
you dont need a hub splitting tool, but it is advisable to use the proper one for the job.. when i fittted my suspension i just whacked a cold chisel in there to open it up.. so long as you are carefull it wont do any damage to the hub
Yer but you know what your doing tom :rofl:, someone with little experiance could easily hit the chisel too hard and crack the hub. :rofl:
:eek: you'd have to hit it flippin hard to crack it:O
if it was going to crack, a hub spilitter would probably crack it too
