Cambelt change and service advice needed
The vRS has just hit 55k so i am gonna get the belt and water pump done as welll as a service
Q1. do i buy a geniune belt kit if so does it come with tensioners etc
Q2. i am going for the metal impellor pump good idea?
Q3. What service items do i need eg plugs, pollen filter,
Q4 Can someone give me a definative answer on the oil i want a good fixed interval oil perhaps millers from GSF as i am going onto fixed as of this service
Any other thoughts will be good so feel free to fire away
:thumbup:
Bump
As far as i know VAG dont do kits for the 1.8T. They do for the diesels and the 1.4 16v for example.
To be honest you want.
Cambelt
Cambelt tensioning roller
Roller damper
Water pump (metal impeller ideally)
Engine mounting to block bolts (3 x 16mm)
Engine mounting to chassis bolts (2 x 18mm)
Service should be pollen and oil filters. If your going to GSF see if you can get some Quantum oil, great stuff and much cheapness.
Cambelt
Roller damper
Nice one ross do you think genuine parts or GSF gear
Just got the bottom of the thread thanks mate
I need these as they are undo once items yes/no ?
I'm sure there's a proper name for them
And the quantum oil which grade 5-10/40 please advise again dude
Yeah the bolts should be replaced as they have a protective coating on them which comes off when removed.
Two choices on the oil, the silver can semi synth 10w40 is just fine but they also do a fully synth variety in a gold can.
Nice one again as always
If you do a good job mate, Your doing mine.
I ain't doing it myself but i'm sourcing the parts for my bud who is doing it for me
I'd have ago with him but i aint got time and i feel i must let him charge me for something as he let's me do loads of stuff for free and
