How to fit dragon box
hi peeps, just bought a dragon box 2nd hand but it came with no fitting instructions. Has anybody got any pictures of where it all connects too plz im desperate to get it fitted.
thanks
Take off the engine cover. Look to right hand side of the engine block there is a big connector with a screw fixing. Unclip the red clip that prevents you undoing the connector, then unscrew and remove the connector. Connect the now loose connector onto the Dragon loom, make sure you line up the connectors, there are white marks to show you where to aim. Connect the other end of the Dragon loom on the engine block connection.
Then just connect the power connectors on the top of the battery terminals and you're ready to go. Test it works by starting the engine, and if everything is OK, tuck the box like I have done behind the headlight, next to the battery.
Oh and don't expect a sudden big increase. The box will subtly increase the power over about 2 full tanks of fuel.
thanks
the first thing to do is remove the fuse from the holder on the red wire
next undo the plug connector on the R/H/S of the head , you will need to pull out the little orange clip a bit first , this will allow the connector sleeve to twist anti-clockwise , then plug the Dragon box connector onto the head and the other Dragon box connector to the original loom from the head , obviously twisting the connectors together to secure
then join the positive and negative terminals to the battery , red wire to pos+
then refit the fuse to the holder , tuck all the wires out of the way and secure the box somewhere out of the way
now test drive , and feel the difference (hopefully)
obviously if you are unsure as to what you are doing , don't do it
the usual disclaimers apply
P.S. i've got one to fit , had it over a month and not got round to it yet
i see you are in Chester , if your not sure , i might be able to look at it for you
cheers lads thank you. im gona giv it a go
