Offset / PCD etc Octavia vRS
Question from n00b.
What`s the offset/pcd/stud holes required for the octy vRS wheels in 16", 17" and 18"?
Cheers in advance ;)
Standard 17's are 5x100 ET 35 if i remember correctly ;)
You don't :P
PCD 5x100
Wheels are 7x17 ET38
Will the offset be the same for the larger wheels (and the 16"`s)?
no.. its complicated... normally the smaller and narrower the rim the lower the offset...
but when the rim gets wide enopugh to hit the strut then you reduce the offset back to push it outwards.... its a bit fluid....
Standard 16" alloys for the vRS are 6.5Jx16H2 ET42.
...and anyone care to quote for the fabia vrs?
In standard 16" and upgrades to 17" please?
17" tend to be ET35, unless they've been ordered with different offset *cough! ;)
The Octy vRS wheels (ET38) fit fine :thumbup:
You don't :P
PCD 5x100
I should have known you'd pop up like a bad smell :P
Then again, driving a diseasel you'll be an expert on bad smells now :D
