Left foot braking?
I want to be able to left foot brake.Is there a way to disable the way that the power is cut when you touch the brake pedal?
Its a 2003 octavia PD130 btw.
Why would you want to do such an antisocial thing?
cos its good fun :thumbup:
Disconnect the sensor on the brake arm and put in an extra circuit to light the brake lights allegedly your Honour !
disconncting your brake light sensor will also put a fault in your system. also if you have curise control may not function correctly.
have you ever experienced catching your wheels on the kerb :o
have you ever experiened writing off a brand new fabia vrs. like a p**ck
If you keep the sensor intact but just not registering application the system does not seem to notice. I don't have cruise but I could see that overide functions would be problematic. Ta
if you keep sensor connected but just not in use that would be different because you still have a complete ciruit show it would not show a fault.
