octavia mk2 radio removal
can someone tell me how to remove the radio as i need to fit the wiring for the phone system many thanks sorry have you got to take the whole trim off or can you get away with just the trim where the four screws are ive looked at the link just wondering if anyone has removed the radio without removing the trim many thanks
Are you plugging directly into the headunit or using a plug and play type device?
yes by removing the main plug and plugging the elan-emk 050 mute box inline
Exercise extreme caution when removing the 4 plastic blanks as they are very easy to scratch.
so they just unclip with out removing the whole trim
Yes indeedy :)
Although you can just pull the trim surround off to make life much easier.
I always take off the larger outer trim myself.
You'll possibly struggle for space if you've got a big lump of mute lead to plug in. If you also remove the top storage bin you could try and pull the wires into the void between the radio and steering wheel.
