Flat battery - now EPC light on dash.
Hi guys, im after some advice.
Two nights ago, some idiot :rolleyes::cool: left his lights on in the car. I used a battery pack the following night to start her up and took her for a long drive. The car is fine now in terms of starting etc. The only two downsides after this event are that....
a, the throttle isnt as smooth (probably a TB recalibration needed?)
b, the EPC light is permanently on in the dash pod.
I dont have access to VAGCOM. Can anyone offer any advice on why the EPC light has been on since the battery died.
Cheers,
Lee
EPC - Electronic Power Control
System includes
Throttle body
Throttle pedal
Brake light switch
Clutch switch
You got it in point a) I would think, when the TB looses its 12v then it looses its basic settings.
Thanks. You are a top knucklehead. (read it in the other thread - pmsl) :rofl:
Can it do any damage/cause any other issues as I wont have access to vagcom again for sometime?
Cheers,
Lee
You could try leaving the ignition on for a minute (engine not running), to try and reset the throttle body.
Really? I will try this in the morning. Thanks :thumbup:
this happened to me on my bora as well, took engine management fuses out, put back in, try also both with ignition on and off, it worked with mine
