How to adjust the windscreen washers?
Is it possible to adjust the direction of spray of a Superb
Most washer jets on modern cars tend to be a fixed and sealed spray unit. So you can't actually adjust them! If your spray pattern is not great, chances are the jets are probably at least partially blocked. I guess you could take them out and try soaking them to loosen any crud that might be stuck in there, and/or blow them out with an air line. The only other option is to replace them, not ideal I know, but they shouldn't break the bank. Hope that helps.
have you tried using a pin?
Mine are adjustable, you slide the front up or down, depending on the direction of travel you want the water spray. I bought a set of these a few years back as wanted to put them on my SEAT Leon. They cost about
As SJFISHER67 has said you can adjust the spray up and down on them by applying a little force.....as for the spread I am not too sure.
How much are new nozzles? Not dear I dare say, and 30 seconds to fit... Personally, I wouldn't mess about with em.
FWIW one of the jets on my Passat was very low down on the screen, and when I looked it had just come unclipped from its holder. Popped it back in and jobs a good 'un. :thumbup:
on the nozzle remove the middle bit with the hole and put in upside down.
