Torque Question OctII vRS
Just going through the technical stuff of the new VRS and the Skoda tech sheet gives an torque of 280 Nm, yet I was looking at the Revo website, where they state that the vRS has a torque of 207 Nm... quite confusing as it seems that by fitting the Revo programme the Bhp goes to 255 (which sounds good :) ), and the torque goes to 285 Nm..which again would be good if the engine was producing 207 Nm, yet a bit to the low side if the engine has a 280 Nm as standard.
got a bit confused with this.. :confused:
Does anyone has an idea of which of the two values referred for the normal torque, i.e., the 207 Nm or the 280Nm, applies to the vRS?
I think it is 207 lbs ft of torque which is I assume equal to the 280NM quoted on the Skoda tech sheet. Could be wrong though.
Standard torque on the TFSI engine is 280Nm = about 205 lb ft. (Rule of thumb calculation divide by 3 multiply by 2 and add 10%)
Maybe Revo have their Nm and lb ft mixed up?
the Revo site is quoting the Torque figure in Lbs/ft rather than nM :)
oops, beat me to it
Torque in lbft multiply by 1.35582 to get Nm
207lbft x 1.35582 = 280.6Nm
My formula is more memorable :D
You won't get 255hp but you will get upwards of 300lbft.
Have a look here JKM Rolling Road day Gallery
Don't be put off by the fact that you WON'T achieve 255bhp (more like 235bhp with a REVO map and any others come to mention it!), it's the torque that will impress you most, as Stu says it's in excess of 300ft/lbs which is plenty enough to push you into your seat :) .
Good luck if you do decide to go down the route of remapping your car, I'm fairly confident that you would'nt regret it ;)
Thanks guys.. I think revo should go with getting the proper units on their advertised values.. I am more interested in torque rather in Bhp..torque makes all the difference especially while overtaking and try to get out of a sticky situation (greek roads and fellow greek drivers :( )
so that means that the Revo software would give theoritically about 380 Nm, mmm
that is 100 Nm more..that is more than enough to weld a grin on my face for the years to come. :D
Thanks guys for all the wishes, as I said in another post I am going to get an Octavia, was looking for the 4wd (octI) but decided to treat myself to the new OCt II vRS, and I think I could get the dealer to get the revo fitted.. no need for heated seats here in Greece.. though it was something I wished for back in my UK days...:rolleyes:
Mine is more accurate ;)
Steve
Bahnstormer's is easier to do in your head though. ;)
... and is actually accurate to better than 1% :eek:
hey..on the ground of conversions..I found this one while trodding around the web.. Unit Conversions
lots of converters :)
