vRS fuel consumption
Hi all
Just had 30K/3 year service, and oddly enough the mpg has improved markedly, especially around town. Used to get 35 ish on the 3 mile drive to work, but now it reckons 42.
I'm sure I'm driving the same, if I go really easy I can get an indicated 48 !!
As they didn't even change the air filter, and no specific faults were fixed I'm surprised at the change.
Any ideas ?
(Not that I'm complaining, you understand - just puzzled)
I know what u mean Ricko,
I used to have a pd100 before and that was amazing at fuel consumption.
Whatever they did to the car please tell me cos mine is not soo clever.
But, I would take the readings with a pinch of salt tbh.
Looking in Autodata Software; The 30k service involves the following:
Vehicle Fully Raised:
Engine Oil leaks - Check/Report
Engine Oil - Drain/Refill
Engine Oil Filer - Replace
Vehicle Half Raised:
Front Brake pads - Check/Report
Rear Brake pads - Check/Report
Front Brake discs - Check/Report
Rear Brake discs - Check/Report
Brake linings through inspection hole -Check/Report
Under bonnet operations:
Diesel fuel filter - Drain
Service interval indicator - Reset
It may be that a problem which was listed by a fault code was repaired (a few members here have reported a notable difference in fuel consumption from changing the air filter/glow plugs)
Look on your job sheet from the dealers and it will list the items that were inspected/changed...
well if they drained the fuel filter would it be possible that there might of been abit of dirt in the filter causing low mpg?
Unlisted service item
'Re-calibrate :rolleyes: ' mileage computer ;)
Hi all
Any ideas ?
there is no way i would start the car up for a 3 mile drive to work :P
Know what you mean - I bike it sometimes but I often have to travel off site ...
Still at 39p/mile there's a bit of profit in it at this mpg :rolleyes:
