fitting d/v to octy
:confused: :confused: will putting on a aftermarket dump valve(not recirc) on my car bring on the cel light ?
thanks in advance for any info
yes it will.
but forge IIRC now do a proper dump valve for the 1.8T.
sarah at awesome will give you more info. try searching, its there somwhere, been thinking of getting one myself, but not long had the forge 007.
the 007 and an induction kit give a nice noise if that's what your after.
I have the forge splitter on mine. It's a very nicely made piece of kit and works a treat. I had a little trouble setting it up but a quick call to forge had it sorted. The splitter comes with a little blanking plug which replaces the trumpet if you want to run it in stealth mode.
Hi
There you go you see you dont need me , there are many clever people here that can help ;)
Yes the splitR is the one that will fit the car and not bring on any warning lights
We have one in stock and they are
whats this about fitting dv's in reverse?
You can do that on the 007p to give extra noise , but not on the splitR I am afraid
Sarah
why would you put something in reverse that not meant to work that way. surely its not good for the engine
