glowplug warning and lamp fault.... co incidental??
Hi
I have an Octavia estate 1.9 deisel.
Problem.
Glowlight warning light comes on after a few miles but only when headlights are on. If I switch the headlights off the warning light goes off.
Also:
With headlights off; when I brake the n/s sidelamp comes on with the braking lights at the back.
With headlights on; all the braking lights come on whether I'm braking or not and the glowplug warning light comes on after a couple of miles.
This is really baffling. If anyone has any solutions or suggestions I would be very grateful.
Alex
A couple of possibilities:-
1) Some, ah, clown has put a 5/21W bulb into a 21W holder or vice versa (rear clusters).
2) Bad earth or short-circuit on rear clusters, including on high-level lamp (probably where it passes from body to tailgate).
check that the dual element bulbs are ok . had one where the element had melted and was touching the other.
