for Antan re power steering fault
Hi Antan
re your problem in this thread
http://www.briskoda.net/forums/ask-tech/another-fabia-steering-prob/38134/#post994532
which I cant reply in cos I'm not a freedom member so I'll post here and maybe get your attention or if some kind sole will post it in there for you.
The problem I had turned out to be the power steering pump it had stopped functioning altogether so I replaced it with one from a breakers and that cured the problem.
If you have checked the feeds to the pump and battery connections and battery
condition (as stated the pump uses a lot of juice) and their ok I have no doubt your pump is faulty .
they come in at
Thanks!
Accidentally stumbled on the thread here :)
First off, I'll go back to my VAG workshop and try to sell them back the steering angle sensor :)
So, next up I guess I'll have to check the battery and the feed to the pump as you say, though I don't really know how to do that or what voltage is right and wrong. Hopefully VAG will help me do a quick diagnose, considering they screwed up (my opinion) last time.
In the worst case scenario, if the pump is broken, I think the insurance company will take care of it.
Thanks a lot for helping me out! Makes me think I'm actually on the right track :)
